Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Bilstein internal bushing cut
    Jul 2004
    Default Bilstein internal bushing cut
    And found that this eliminated bottoming out. I have Eibach springs and no rubber rings under and above the suspension springs at front. The car seems to have gone lower after the cut, suggesting that the bushings were on the way. Approximate length cut off - 4 centimeters:
    deleted air conditioning
    looks good mate
    Jul 2004
    Quote Originally Posted by BigKriss View Post
    looks good mate
    thanks Kris
Size:  96.1 KBName:  Strut1.jpg
Size:  90.8 KBName:  StrutBottom.jpg
    Billies are the whip man!
    The bump stop is on the bottom of the shock ??
    Jul 2004
    God, the first picture is so bad.
    Jul 2004
    yep... the shock is "inverted shock".
    so it has to move up and down, and gets the yellow enclosure to make it possible, whose diameter is that of original normal shock absorber - meaning the actual Bilstein's shock absorber is thinner than regular Boge's...
    Ok. I didn't know.
    Jul 2004
    I only found out last year myself, 9 years into having them...
  1. for internal use only - the E34 bible
    Last Post: 12-09-2008, 05:49 AM
  2. video-internal-combustion-engine
    Last Post: 11-26-2006, 05:27 AM
  3. M30/535i oil pan internal view
    Last Post: 10-08-2006, 10:45 AM
  4. Internal Gearbox Repair - recommendations?
    By myles in forum 5 Series BMW
    Last Post: 09-10-2004, 05:08 PM
  5. Where does the internal rearview mirror latch on to?
    Last Post: 06-18-2004, 07:31 AM
Tags for this Thread
