Results 1 to 10 of 14
Thread: noob question on E34 front inserts
    Jul 2014
    Default noob question on E34 front inserts
    Hi All from sunny Wales!
    I have a late 93 525 TDS Touring, currently an Auto soon to be manual
    I recently picked up a set of Bilstein B8 front inserts with Alpina springs, and rear dampers with Alpina springs as well, I believe they came from a 535i.
    my question is was it around 1990 that the front strut inserts changed to a larger diameter body and larger diameter top spindle thread?
    I tried the inserts in some spare 525 front leg assemblies I have, the locking ring is the same thread but there is a fair difference in the O.D of the insert, the Bilstein is about 45.8mm (its a 40mm inverted insert)
    the Boge unit that came out was a 26mm rod and roughly a 50mm o.d.
    also different is the top spindle thread, my B8's are a 19mm nut, so I guess M12, and the car is a 22mm nut so M14.
    As far as I know all the inserts should be inter changeable except the nuts and diameter of the top that goes through the mount. Boges come with a small shaft and a collar so it fits both varieties here in the US. Difference in body diameter should only effect the volume of oil added to the housing. I always add too much and the extra oozes out upon tightening the collar nut.
    I have not heard of an insert not fitting the housing.
    I can confirm that, I've swapped newer into older struts before, just by changing the top.
    Jul 2014
    Ok thanks guys, so I guess the top lockring locates the insert rather than just holding it in, so if i add a sleeve to the top spindle or get some early top mounts ill be fine.
    Oldham, England
    If you are talking 535i, the changeover date was 7/90. My 2/92 525i had pre 7/90 inserts matched to the proper top mounts from the factory. But it wasn't Euro spec. All you should need to do is match the diameter and height of the pin with the hole in the top mount. BUT I am not sure this applies to the diesel or 520i. I think they had odd ball strut housings
    Jul 2014
    I believe the tds shares most of its underpinnings with the 520 and 525, the 30 and 40 being v8's I believe just had different springs and inserts
    Oldham, England
    Quote Originally Posted by welshpug View Post
    N America didn't get the diesel or the 520 so you may not get a definitive answer here. I am sure there is a thread somewhere on forumbmw5.co.uk which confirms they differ from the 525i +. Maybe you know the site? I had Bilsteins on the rear of my E34 but they were not B8s. IIRC they were B6s.
    Total guesses, but this is what I'd expect, based on engine and body type:
    Small nut
    All M10 518i
    All M20 520i/525i
    Early M50 525i
    Early M30 530i/535i
    S36 M5
    Large nut
    Late M50 520i/525i
    Late M30 535i
    All S38 M5
    All M40 518i
    All V8 (M60) 530i/540i
    As the Tourings came later, they MAY all be Large nut.
    Of course it may well depends more on the factory and production run rather than the model/engine code.
    Sorry, M10 518i should read M40, and M40 518i should read M43.
    For all those running the e34 best suited to becoming a hybrid powerhouse...
    Jul 2014
    Finally Figured last week what the differences were from early to late E32/34 top mounts, basically make a 1mm sleeve to take the spindle from 14 to 16mm! Also figured that the inverted B8 bilstein front insert is located by the locking ring so the 5mm gap around it doesn't matter (the Boge o.e insert was a snug slide in fit)
    20140720_122247 by WELSHPUG, on Flickr
    Today I got round to fitting them with the Alpina springs, sorted the reverse rake right out, looks superb now
    front bump stops essentially non-existant
    20140720_120415 by WELSHPUG, on Flickr
    Rear dampers a total doddle!
    20140720_171044 by WELSHPUG, on Flickr
    looks spot on.
    20140720_171902 by WELSHPUG, on Flickr
  1. Noob Question
    By geneb in forum 5 Series BMW
    Last Post: 12-24-2006, 09:37 AM
  2. noob 535 i question
    By Clayman in forum 5 Series BMW
    Last Post: 11-08-2006, 04:04 AM
  3. Noob question on lowering my car.
    By vuyodaddy in forum 5 Series BMW
    Last Post: 07-22-2006, 03:44 PM
  4. Hi I'm a noob
    By 525i! in forum 5 Series BMW
    Last Post: 05-31-2006, 08:46 AM
  5. Replies: 5
    Last Post: 04-28-2006, 07:51 PM
