Results 1 to 9 of 9
Thread: Accufab adjustable fuel pressure regulator
    Default Accufab adjustable fuel pressure regulator
    I am trying to install this at the moment. It goes on the stock location of the old fuel pressure regulator. I had to get some longer fuel hose. I am going to hook up a fuel pressure gauge soon.
    It was leaking though. I ran the car and petrol was coming out. A second time I put some plumbers tape on the fitting thread. It was leaking still but not as much as before. I will try tomorrow and look to install a new fuel pump too.
    Looks nally dude
    You have to nail the bend in the hose and its length of course- Are you going to get an L fitting for the bottom of the FPR?
    I will try. I haven't found one yet though. The thread is M14x1.5. This is the manufacturers fitting http://www.napaonline.com/Catalog/Ca...928_0412991622
    The hose will kink if I currently make it shorter.
    May 2005
    central coast nsw au
    Hi ya Big K, can u tell me about this device - adjustable fuel pressure regulator. I just got me a 535ia exec and im curious about the adjustable part of the system. what does it do?
    Hi Matt. It adjusts the fuel pressure to the fuel injectors. I don't know how useful it will be overall but I want to use it in tuning when I turbocharge the car. A gauge will need to go on to see what fuel pressure its running.
    May 2005
    thanks Big K
    p.s think I just bought another e34 that makes 3, oh ****
    Jul 2004
    Looks good Kris. Thanks for posting. I see you got an additional temperature sensor there.
    deleted air conditioning
    I installed this today. You can see the video here. http://youtu.be/kq2chxCZZts
    I purchased some fittings to make it work. M14x1.5 to -4AN, then a -4AN 90 degree bend, then a -4AN 180 degree barb that goes to the return line. The M14x1.5 fitting was leaking so I put a fuel injector o-ring in there that I cut out a bit to make smaller. It stopped leaking after that. I also added some loctite 567 to these threads.
    I then adjusted the fuel pressure to 42 psi on the gauge with the vacuum hose off and on it goes to around 37 psi.
    Jul 2004
    Looks good.
  1. Fuel Pressure Regulator...
    Last Post: 04-05-2008, 06:36 AM
  2. HELP! can't get fuel pressure regulator out of fuel rail....
    Last Post: 01-21-2007, 09:26 PM
  3. Fuel Pressure Regulator DIY?
    By InfernoM3 in forum 5 Series BMW
    Last Post: 04-15-2005, 05:16 PM
  4. fuel pressure regulator
    By duckloads in forum 5 Series BMW
    Last Post: 04-01-2005, 03:24 AM
  5. Replies: 4
    Last Post: 09-14-2004, 07:15 PM
