Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: E34 530 540 power steering heavy
  1. #21
    petroleum jelly has a melting point is a shade over body temperature, so it won't last behind the wheel once the sun hits the windscreen. You need some carbon grease with a high melting point for the airbag and horn rings.
    Bearing grease or lithium grease be fine? Now that I have ventured in here I am not shy to go in again. It was very cold when I did this so I used weak Vaseline... primarily because I couldn't find the lithium.
    Update, I think the petroleum jelly is getting tired. Need to upgrade to lithium and get more than 1 year out of it. The summer didn't seem to make a difference although I'm pretty sure it has no lube now.
    Well the vasoline is still working, don't fix it if it aint broke.
    May 2015
    Nice thread..BTW I used Liqui Moly ATF III on my E34, when I emptied the steering lines. I hope this wasn't the wrong one.
    1989 E34 535i
    M30B35 six cylinder, single overhead camshaft, 3.43 L, multi-point fuel injection
  5. #25
    Maybe something is lost in translation, here in Oz, Vaseline is petroleum jelly.
    The right grease for the job (conductive and high melting point) is probably referred to as 'Carbon Grease'. Not sure if it is what BMW uses on these contacts exactly, but it is probably something like this.
    For non-conductive greases, attached below are some summaries of the main properties/types:
  6. #26
    Quote Originally Posted by Jazz_89 View Post
    Fine for any of the 4 speed autos- and some of the 5 speeders too, (HP18EH) with the black ID plate. If you have green plate, you need to use the BMW lifetime (or appropriate synthetic*) fluids.
    * Meaning they meet the published BMW/ZF fluid specs
    LiquiMoly make very good lubes- your tranny should like that stuff, just make sure you do several changes- to have a hope of getting rid of the older fluid.
  7. #27
    That's the stuff. All I had at the time.
    Update a couple years later...
    Stiff steering back when real cold, turn signal sticking with the wheel and moving when turning. Christmas day and 70 degrees, perfect to check this out and lube it proper this time. Took it all apart and as mentioned above the vasoline (petrolium jelly) was virtually non existant. Not sure why its so tight but took it apart and used lithium grease under the brass clamp. Since it isn't cold can't be positive it is fixed yet. Almost broke that airbag connector that I hot glued. This isn't real easy to do without pulling wires while removing the wheel etc. Patence is not me forte, if I had patients I am in the wrong business.
    Here is a picture I stole off the net of the brass clamp thing I failed to photo myself but shows exactly whats up:
    If you look under that knife there is an access slot for a small screwdriver which is what I did. All you need to do is clean the brass deal and the plastic it rides against and then lube it up. Amazing such a small thing can cause such a big drag issue and noise in turning the wheel but it does.
    Lithium is way to heavy below 35F, it causes the slip ring to pop out of position and pull the airbag wire out. Cleaned it up and just put a small amount on it. Still seems tight at 60F. Not sure what I want to do yet. Might just put it together to see how it works in the cold, might be that petroleum jelly is slipperier... might use pet jelly again cause I had no issue last winter and it was much colder then. Yep that's what I'm going to use.
    Did the trick, no problems at all in the cold like it did with lithium.
  1. Puddle + power steering = No Power steering
    By ahlem in forum 5 Series BMW
    Last Post: 04-20-2013, 08:18 AM
  2. power steering
    By allerston in forum 5 Series BMW
    Last Post: 07-08-2008, 01:15 PM
  3. Power Steering Very Heavy
    By bmw540 in forum 5 Series BMW
    Last Post: 09-05-2006, 09:29 PM
  4. Power Steering
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 07-04-2006, 05:32 PM
  5. Replies: 8
    Last Post: 03-22-2005, 03:19 AM
