Originally Posted by
genphreak
For now I left it all in situ and simply bled a lot of fluid through as it didn't come clean for some time. PO used DOT4, but its now using Super DOT4. Not sure if the seals don't like that fluid.
Used my trusty pressure bleeder to positively push the fluid down from the reservoir. Clutch operation feels better and the problem is solved (for the time-being). Will have to see if any more bubbles get in there.
I didn't noticed the jammed gearshift responding to pumping, but that's good advice- thanks Bill. Might be useful if it happens again. Will source some new seals and do a full removal, inspection and re-fit later- when I get the time.
