Unscathed
Originally Posted by
Bill R.
Yours should have the 2 stage wear indicators on it, if the wear indicator has any wear at all on it even though its not down to the wires you won't be able to reset it correctly. I have run into this many times, reset with scan tool still shows go into idrive menu and reset through front and rear brake pads, each are set separately. Still shows.
Replace sensor and reset through idrive menu and it works fine.
as seen here
Sorry, i should have been clearer. The wear sensor is untouched. It did not come in contact w the rotor at all. I replaced the pads and rotors w the onboard info still showing 800 miles and the pads still had a teeny bit left - like one or two mm.
I will give the scan tool reset a shot over at a buddy's. Then try a new sensor.
Thanks!
Link to my M50 engine rebuild thread
http://www.bimmernut.com/forum/showthread.php/43339-M50-Eng-4L30E-Trans-RRR-Far-More-Than-I-Ever-Expected?highlight=93+525+paul
