Results 1 to 5 of 5
Thread: Puddle + power steering = No Power steering
    Sep 2007
    Michigan
    Default Puddle + power steering = No Power steering
    Any suggestions as to the cause of this? Belt slipping when wet?
    Any noise?
    Cracked/ing pipe leaking?
    Cracked pump housing
    Cracked reservoir?
    If it's a small puddle and you still have fluid level, maybe there's a blockage/failure causing extreme pressure.
    Sep 2007
    Michigan
    I should have said WATER puddle as in rain. No leaking power steering fluid is present.
    Is the belt tight?
    Sep 2007
    Michigan
    I'll be checking belt tension and belt condition and a oil-leaking bolt on the front of the motor right after I change a thermostat housing, o-ring and bleeder on an e30. I'll report my findings.
  1. Power Steering
    By PLATINUM in forum 3 Series BMW
    Last Post: 09-02-2008, 09:28 AM
  2. Power Steering Help!
    By realness in forum 5 Series BMW
    Last Post: 04-01-2008, 02:52 PM
  3. Power Steering
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 07-04-2006, 05:32 PM
  4. Power Steering
    By xtmsports in forum 5 Series BMW
    Last Post: 04-04-2005, 10:46 AM
  5. Replies: 10
    Last Post: 02-01-2005, 01:25 PM
