From an ald shogun post, go figure.
You can establish a code that will prevent the engine from being started unless the code is entered.
Establishing and activating
the code:
Stop the car engine.
Turn the igntion key to the RADIO position.
Press the CODE button. Display shows "- - - - CODE".
Enter the code with the function buttons (1000,100,10,1).
To store the input press the S/R button.
Turn the ignition key off - to position "0". Indicator lamp lights on the CODE button.
Car is under the code and does not start while to turn ignition key.
Deactivate the code:
Turn the igntion key to the RADIO position. Display shows "- - - - CODE".
Key in the code.
Press the S/R button. The time display appears.
Start engine.
Code lost or unknown:
If you do not have access to the code, the emergency de-activation procedure will have to be carried out.
Disconnect the battery for five minutes. Reconnect.
Display shows timer counting down 15 minutes.
During this time press CODE, enter your code, press S/R, start engine.
