What happens when you push the driver's lock down on the inside with the door open? Do the other doors lock? Does everything automatically unlock immediately again? (or possibly all the doors except the drivers unlock?)
Usually when the actuator motor fails it fails in both the lock and unlock positions.
If it won't lock or unlock from the passenger door I would suspect the actuator motor.
Shayne wrote an article about this BMW E34 door lock actuator repair
Did you check the fusible link behind battery. 80A cheapest from VW. Go to a VW dealer's parts counter or a VW parts retailer and ask for an 80A Fusible link. About $1.
If you have a local BMW dealer and insist on the BMW part ask for part number 07119978840
BMW E34 Website
In case your battery is under rear seat:
The images of/for the location and style will probably be incorrect for your car. In all likelihood yours will be under a black cover with a heavy gauge wire running to it directly behind your battery. Under the rear seat bolted with two 10mm nuts, the black cover is much like the one pictured at the shock tower.
It may also be due to a broken part inside the doorlock an overload for GM (internal reversible overload relay).
The general module = GM has an internal electronic reversible overload relay. Translate this with google which I posted on the German forum. This I posted with regards to windows and sunroof, but same applies to locking/unlocking:
Fensterheber und SHD= electric sunroof:
Es gibt da Prioritaeten wie das ablaeuft in der Beschreibung ZKE.
Das Relais schaltet ab
-wenn laenger als 60 Sekunden ein Strom von ueber 36A oder
wenn laenger als 0.3 Sekunden ein Strom zwischen 36 und 60A oder (Ueberlastung)
-wenn laenger als 0.1 Sekunden ein Strom groesser als 60A fliesst (Kurzschluss)
Um die Laststromkreise TSH/ZV/ZS/FH/SHD sicher vor Ueberlast zu schuetzen, wurde zusaetzlich zur 30A Sicherung eine elektronische (reversible) Stromsicherung eingebaut.
Im GM wird der Spannungsabfall am RM gemessen, und je nach Spannungsabfall (Stromschwelle) unterbricht das Sicherheitsrelais den Laststrom .
Die Abschaltwerte der 30A Sicherung werden dabei nicht erreicht (diese wurden nur dann schmelzen, wenn ein Defekt an der elektronischen Sicherung vorliegt).
Die Ansprechschwelle dieser elektronischen Sicherung ist so gelegt, dass immer vor Ueberlast der angeschlossenen Steuerungen automatisch abgeschaltet wird.
Ein automatisches Wiedereinschalten erfolgt nach 60 Sekunden!!!!
Jedoch nur dann, wenn diese Verbraucher abgeschaltet waren bzw kein Kurzschluss vorliegt.
Ein automatisches Wiedereinschalten kann 6 x erfolgen bei eingeschalteter Kl. 15.
Diese Sperre wird aufgehoben durch Ausschalten der Kl. 15.
Um die Ausloeseschwelle beim gleichzeitigen Einschalten mehrerer Verbraucher nicht zu erreichen, koennen bei der FH-Steuerung gleichzeitig nur 2 gleichzeitig angesteuert werden. Werden mehrere Tasten gleichzeitig betaetigt, so werden nur die zwei ersten Befehle ausgefuehrt.
Sollte bereits bei 2 eingeschalteten FH die Ueberlastgrenze ueberschritten werden, so wird ein FH abgeschaltet. Dabei haben die FH vorne Vorrang.
in brief: 6 times overload for
and the GM switches that function completely off and switches it on when ignition has been switched off once for 60 seconds. Terminal 15.
So you might have somehow too much load there sometimes.
See under 10 ZKE
ZKE
ZKE
that is the complete ZKE = central chassis electronics technical training manual.
TSH = door lock Heating—-Tuerschlossheizung
ZV central locking system - Zentralverriegeling
ZS = Central locking system inhibit device
FH= electric window
SHD = sliding/ lifting roof (from ETK)—-Schiebe-Hubdach
