Results 1 to 7 of 7
Thread: 5HP18 ball (one-way check valve) diameter needed
  1. #3
    updated links
    here a copy bulletin of that http://www.europeantransmission.com/....BMW/01-34.pdf
    from this main link http://www.europeantransmission.com/...MWtechinfo.htm
    https://www.transmissiondigest.com/november-2001-issue/
    Before or after overhaul, vehicles equipped with ZF-5HP-18 may exhibit a bind-up condition in the Manual 2 position, 1st gear.
    The cause may be that the plastic D-clutch one-way checkvalve assembly in the lower rear valve body (#15 in Figure 4) is broken, allowing the B clutch (reverse input clutch) to be on while the D clutch (low/reverse clutch) is on in 1st gear.
    Replace the D-clutch one-way check valve assembly (See Figure 5) with a new assembly from ZF, or a new aluminum checkvalve assembly offered by Mario Aristides (phone 305-666-3544 or fax 305-666-8238).
    https://aftermarket.zf.com/remotemed...fc-5hp19fl.pdf
    https://www.bmwe34.net/E34main/Troub...ch%20Guide.pdf
  1. Replies: 4
    Last Post: 11-14-2010, 06:03 PM
  2. check valve
    By 2fast in forum 5 Series BMW
    Last Post: 04-20-2007, 07:32 PM
  3. 5HP18 valve body removal
    Last Post: 02-19-2007, 01:18 PM
  4. Help! Vin Check needed if anyone can
    By Don in forum 5 Series BMW
    Last Post: 05-21-2006, 07:22 PM
  5. 540i exhaust pipe diameter needed
    Last Post: 01-31-2005, 02:18 AM
