Results 1 to 7 of 7
Thread: 5HP18 ball (one-way check valve) diameter needed
    Default 5HP18 ball (one-way check valve) diameter needed
    I hope someone can help, I need the ball diameter of ZF part number 1043 226 028 Valve, "D" CLUTCH ONE-WAY CHECK VALVE ASSEMBLY made of plastic, for that also a modified
    "Replacement" ALLUMINUM CHECK VALVE is available http://www.europeantransmission.com/...MWtechinfo.htm
    also in the parts catalog shown on page 27 of 42, Position # 51.200
    BMW ZF-5HP-18 "BIND-UP" WITH SELECTOR IN MANUAL "2" POSITION, 1st GEAR
    COMPLAINT: Before or after overhaul, vehicles equipped with ZF-5HP-18, may exhibit a "Bind-Up" condition in the Manual "2" position, 1st gear.
    CAUSE: The cause may be, the plastic "D" Clutch One-way Check Valve assembly located in the Lower Rear valve body, shown in Figure 2, may be broken allowing the "B" Clutch (Reverse Input Clutch) to be on while the "D" Clutch (Low/Reverse Clutch) is on in 1st gear.
    CORRECTION: Replace the "D" Clutch One-way Check Valve assembly , as shown in Figure 1, with a new assembly from ZF, or a new "Aluminum" check valve assembly offered by: Mario Aristides. Phone (305) 666-3544 or Fax (305) 666-8238.
    "Original" PLASTIC CHECK VALVE ZF Number 1043-226-028
  1. Replies: 4
    Last Post: 11-14-2010, 06:03 PM
  2. check valve
    By 2fast in forum 5 Series BMW
    Last Post: 04-20-2007, 07:32 PM
  3. 5HP18 valve body removal
    Last Post: 02-19-2007, 01:18 PM
  4. Help! Vin Check needed if anyone can
    By Don in forum 5 Series BMW
    Last Post: 05-21-2006, 07:22 PM
  5. 540i exhaust pipe diameter needed
    Last Post: 01-31-2005, 02:18 AM
