Appreciate the responses, some responses of my own...
Originally Posted by
genphreak
By dead you mean no lights on the dash at all?
Yes, nothing - no lights, no reaction, no nothing. As if no power exists in the car. It's like the show Revolution!
genphreak
Tiger is dead right, if it suddenly happened, it could be battery- they die like that and sometimes even measure 0v, when they die.
Given the history- we would suspect battery from the start (years ago), so would have to have counted it out to get ot this point.
I dont understand the above - suspected battery, but now counted out? As I mentioned, the battery has been replaced (less than a year) and also checked - it's working fine, terminals tight, etc. Since the non-starting thing happens very randomly, and not very often, I'd find it hard to be related to a battery. Bad connection, yes, but source - that seems unlikely to me.
genphreak
But regardless, the fusible link is a good thing to have reliably replaced.
It could be the fusible link if definitely not the battery. Measure the standing charge and if <12.5V, you have a problem. Should have 12.7V minimum to start.
Well this was just replaced and I can only expect that he did the job correctly. He tested and inspected after installed and all was working fine. Not sure how else to check it.
genphreak
Suspect in order:
1. Battery (also check it is a large DIN88 battery, the smaller DIN66 will work but not for as long (it will fail early as well as run out of capacity quickly in harsh conditions)
2. Fusible Link (they are not easy to install properly- requires inspection and testing)
3. Alternator Regulator (starts to provide erratic/intermittent charging of the battery)
4. Alternator
I believe all of these parts have now been replaced with OEM parts. I'll have to verify. Not sure what you mean by DIN88/66 battery - I'm guessing that's a size thing?
genphreak
Did you only remove the optional Alarm module?
Did you leave the Drive Away protection/immobilisation (DWA) module?
Maybe? I removed the black box that had BMW on it, disconnected it from the power and electrical cables. I'm not sure what the DWA module is, so I'm pretty sure I didn't touch that. If it is something I can remove, I'm all for it!
thanks
Eric
1995 525i
Huntsville, AL
