the problem is that BOTH batteries must be good and in same condition on the 850.
Do you have a load tester? Better get one, pretty cheap from Harborfreight, I also got one.
Car and Deep Cycle Battery Frequently Asked Questions (FAQ) Section 4
Also check both fuel pumps. In case the fuel pumps did not work for some months, it could even be that both are stuck.
Plus check the fusable links in the trunk next to the batteries. We had a similar case some years back with an 850. Sometimes started, sometimes not. Tested and changed a lot. In the end it turned out that one of the TWO fusable links had a haircrack which sometimes made contact and sometimes not. Just follow the battery cable, the fusable link is hidden under plastic heat shrink usually. And remember, there ate two of them in the trunk. We checked then only one, but in the end we found that the other one was broken.
