Results 1 to 10 of 10
Thread: Headlight start right when the ACC switch is on
    Aug 2004
    Dubai
    Default Headlight start right when the ACC switch is on
    Hi everyone on board, it's my first post since ages.
    i went on a month vacation and when I came back to drive my car it started some strange behaviour when engine is idle, after the engine is at op. ttemperature it dips as if it's gonna switch off then runs normal again.then runs smooth but emission is bad as I can see black smoke. Associated with this is strange dip been headlights the either turn on then off when I crank engine or they stay on and then my dashboard lights are always off and turning signals wouldn't work. When am driving sometimes the dash lights are back and I get a message in German "wasserwesen fullen"
    Engine runs alright but I feel sometimes something dragging it back while cruising at 60 miles/ h with rumble sound it's so minor that u feel that the road is a bit rough.
    any idea where do I need to look into? I feel that I got a shorted cable somewhere but I have no idea where to start
    Car is e38 750iL highline Japanese specs 1998
    Thanks in advance
    Aug 2004
    Dubai
    Correction, its "Waschwasser Fullen" also an update on the the symtums: while driving the engine chokes as if it's changing speed then the lights flash off and on and my dashboard lights turn off. While that happens all the signal handle functions stops working including the high beam. This happens on and off while driving.
    First of all check the battery. It may still start the engine, but too low battery voltage can cause such electronic problems.
    That means, make a load test of the battery, not just checking with a voltmeter.
    Aug 2004
    Dubai
    The battery is quite new, but I changed the alternator few months ago with a second hand one, might have a rough output. Is there a schematic diagram or wiring diagram available?
    SpaghettiCoder - BMW
    I still suggest that you make a load test for the battery, especially in hot climate countries the batteries have a very short life.
    There are special designs of batteries for hot climate countries
    Excessive heat and overcharging are the two main reasons for shortened battery life
    A low maintenance battery is a non-sealed battery and has a lead-antimony/calcium plate formulation. Since this is a non-sealed battery, this is the best option for hot climates because it will allow you to add water when necessary. It requires little maintenance.
    Aug 2004
    Dubai
    here are the latest updates,since i had no hazard lights working, signal lights, high beam and dashboard lights i have been told that its the lights control module that causes issues as such and here is a post that i found about it:
    The only obvious link on a previously similar problem experienced by a board member is
    here
    There is chat over at Bimmerfest
    here
    Their post goes on about the symptoms of a failed Light Control Module being " No turn indicators and hazard warning lights, no high beam, no headlight flasher, no fog lights, no rear fog light, no third brake light " My car shows none of the described symptoms, just the offside side-light / eye ?
    It's obviously not a very common fault as there is little discussion regarding this fault.
    so today am gonna find a unit and swap it, yesterday i removed it to check on any dry joints and soldered all the main power joints without any luck. the unit seems to be cheap less than 50$ so fingers crossed.
    let us know how it was solved, I am interested too.
    Aug 2004
    Dubai
    Well now everything is working perfectly after replacing the module as for the engine hesitance and chocking it came out to be the MAFs so I got 2 and the 4 exhaust sensors ( 2 cat. Sensors and 2 oxygen sensors ) since they won't be as good due to carbon build up, hope that helps adding info to the forum.
    Aug 2004
    Dubai
    Something else to add is the the software version should be the same or the LCM will show errors on the obc screen.
    Cheers
    Aug 2004
    Dubai
    A nice page about repairing an LCM Here
  1. How hard is it to replace the headlight high beams switch?
    Last Post: 04-27-2010, 09:30 AM
  2. Need headlight adjust switch !
    By Booster in forum 5 Series BMW
    Last Post: 08-03-2007, 11:58 AM
  3. key won't rotate in ignition switch or start car
    Last Post: 03-12-2005, 10:59 PM
  4. How to replace bulb in the headlight switch?
    By Mario in forum 5 Series BMW
    Last Post: 08-28-2004, 10:26 AM
  5. Will manual tranny start leaking if I switch to redline?
    By Uncle Paully in forum 5 Series BMW
    Last Post: 02-20-2004, 04:30 PM
