Results 1 to 2 of 2
Thread: Bosch Motronic MPi (35, 55 & BB-pin types) 20 pages
    Default Bosch Motronic MPi (35, 55 & BB-pin types) 20 pages
    http://www.gaima.co.uk/peter/BoschMotronic.pdf
    Contents
    Overview of system operation
    Catalytic converter and emission .. 6
    Control functions. . 2
    Fuel injection (MPi) . 5
    Introduction. 1
    Primaryand secondary ignition. . 4
    Primary trigger. .3
    Adjustments
    Adjustment pre-conditions 7
    Idle adjustments. . . . 10
    Ignition timing checks. . 9
    Throttle adjustments.. . .. 8
    System sensor and actuator tests
    Air temperature sensor (ATS) . . . 18
    Airflow sensor (AFS) . 16
    Carbon filter solenoid valve (CFSV) . 28
    CO potentiometer ('pot') 19
    Coolant temperature sensor (CTS) 20
    Crank angle sensor (CAS) 11
    ECM voltage supplies and earths. . 24
    Fuel injector operation. . 14
    Fuel pressure. .. . . '26
    Hall-effect phase sensor (CID, GM 16-valve engines) . 15
    Idle speed control valve (ISCV) 23
    Knock sensor (KS) . 13
    MAP sensor.. . 17
    Oxygen sensor (OS) .. 27
    Primary ignition. . . 12
    System relays. . . .. 25
    Throttle potentiometer sensor (TPS) 22
    Throttle switch (TS) 21
    Pin table -typical 35-pin (First Generation Motronic, BMW)
    Pin table -typical 35-pin (Motronic 3.1, Citroen/Peugeot)
    Pin table -typical 55-pin (Motronic 1.5, Vauxhall)
    Pin table - typical 88-pin (Motronic MP3.1, BMW)
    Faultcodes
    Obtaining fault codes. . 29
    good download...thanks
  1. Replies: 1
    Last Post: 01-09-2010, 05:16 AM
  2. DME MOTRONIC Bosch 1.1 and 1.3 details
    Last Post: 07-10-2009, 09:59 PM
  3. Bosch MOTRONIC 3.1 pinout details
    Last Post: 01-17-2007, 08:15 PM
  4. Bosch Motronic 1.3 - CD or ID ignition?
    Last Post: 06-21-2004, 05:56 PM
  5. Bosch Motronic DME Programming
    By MMarcel in forum 5 Series BMW
    Last Post: 05-03-2004, 07:36 AM
