Results 1 to 2 of 2
Thread: idle too slow to drop
    Default idle too slow to drop
    Hi Guys
    1989 BMW 525 i manual.....car idles fine when the air conditiner is OFF....however when the air is ON.... the car idles fine but is very slow for the idle to return to normal when the revs are increased and I take my foot off the accelerator.....eg when driving and changing gear (say from 1st to 2nd ) I have to pause in neutral for several seconds for the revs to drop......with the air OFF it is OK.....I have replace the idle control valve but has made no difference.....any ideas ?????
    Cheers
    Aussie John
    Vacuum leak is probably the most likely cause. Spray carb cleaners tof ind the leak.
  1. Weird issue: low idle during slow stops...
    Last Post: 07-29-2010, 12:39 PM
  2. Drop it like its hot
    By ArnZ! in forum 5 Series BMW
    Last Post: 09-24-2009, 10:04 PM
  3. Replies: 2
    Last Post: 01-04-2007, 01:51 PM
  4. Volt drop vs fuel pressure drop/stumble
    Last Post: 04-24-2006, 07:06 AM
  5. Replies: 1
    Last Post: 11-23-2005, 09:31 PM
