Results 1 to 10 of 12
Thread: Petroleum-like odor
    Mar 2011
    Appleton, WI
    Default Petroleum-like odor
    Does the E34 use an exhaust manifold gasket? I'm getting a petroleum-like odor through the ventilation system. Can't tell for sure if it's fuel or exhaust. Just wondering what might be causing it. My first thought was maybe a leaking exhaust manifold gasket, but, I don't know if these cars use one. The car has the M50 2.5L 6 cylinder engine. This is my first BMW.
    Any suggestions would be appreciated.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    would be nice if you could tell us which engine is installed. Then someone can answer
    you can also check the exhaust drawings with your VIN on www.realoem.com
    Mar 2011
    Appleton, WI
    It's the M50 2.5L 6 cylinder.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    Oldham, England
    Smell it more when you just started driving it? If so check hoses 15 & 16 below when you start the engine from stone cold. Its common for them to leak with age but they seem to seal once things warm up:
    RealOEM.com * BMW E34 525i VALVES/PIPES OF FUEL INJECTION SYSTEM
    Mar 2011
    Appleton, WI
    Yes, it's mostly right after start up, although I do get a whif every now and then while driving. I will probably get enough hose to replace 14-17. The diagram shows they are clamped to lines 12 and 13, which are presumably pre-shaped metal lines. Are they also clamped to whatever each of them attaches to at the other end?
    Thanks.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    Oldham, England
    If you look to the right of the throttle body, you will see where the hard lines 12/13exit from under the manifold and connect to hoses. The hoses drop about a foot then connect to hard lines at the back of the inner wing near the bulkhead.
    Get your tape measure out and see how much hose you need. Then maybe have a word with your BMW dealer- when I bought a 'hose kit' from them I expected to get short lengths of pipe. In fact I got about a meter! I still use the extra when testing with a fuel pressure gauge
    Mar 2011
    Appleton, WI
    OK, got it. The rubber hoses connect to hard lines at each end. Should be relatively easy to change them out then save for dealing with cramped workspaces.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    Oldham, England
    Quote Originally Posted by 6670charger View Post
    Yep. You could always do the bottom connections from underneath. But why fix it if it isnt broken? I'm betting the hose near the fuel pressure regulator is the culprit anyway. If/when you do the hoses, dont forget the fuel is under pressure - have a nice big rag handy to soak it up. And if its got the silly BMW hose clips on it, you will need a set of mole grips to back them off. They are designed to shear when they reach torque leaving you nothing to put a screwdriver or socket on
    PS Although you are in Germany, I'm guessing you are from the US?
    Mar 2011
    Appleton, WI
    Yes, I'm from the U.S. I'm in Germany for about a year for the Military. Bought a cheap BMW for daily wheels. Really like the car. Just trying to address a few small nagging issues.
    I'll take a look at the clamps tomorrow.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    Oldham, England
    The 'u' missing from odour is a clue After a year you will be able to look up parts in realoem in German. Some of the parts prices there are silly money. Hope you enjoy the stay and the car
  1. gas odor
    By i_willnotlose in forum 5 Series BMW
    Last Post: 01-30-2007, 02:46 PM
  2. Gasoline odor after filling the tank
    By SRR2 in forum 3 Series BMW
    Last Post: 10-16-2005, 03:08 PM
  3. Why would man trans fluid have strong odor?
    Last Post: 08-17-2005, 03:25 PM
  4. Fuel odor update: advice welcome
    By tim in forum 5 Series BMW
    Last Post: 03-18-2005, 12:57 PM
  5. Strong Fuel Odor
    By John D in forum 5 Series BMW
    Last Post: 11-09-2004, 05:58 PM
