E is normal, the
E is normal, the * is winter traction control, such as taking off in 2nd so that you dont spin the tires as easy. Mine worked last summer but not since so I have not used it this winter but I understand that it uses the brakes and ECU to control spin and traction even on turns when and if it starts sliding...pretty cool thing.
Sport mode is pretty much when you drop the shifter into a lower gear, the transmission will shift at higher RPMs and a little firmer. Play around with it, you'll like it!
Reason: .
