Would anyone, who has done this job in the past, like to share the experience? Any tip is appreciated.
I am changing the oil vanos line pipe (#10 in the diagram RealOEM.com * BMW E34 525i Cylinder Head Vanos). There is a banjo bolt with gasket rings. I have two questions:
1) gasket rings/washers I purchased two kinds: aluminum and copper with the same size. Which one is better to put there, copper or aluminum?
2) Do I need any special glue or plastic o-ring or something so that it does not leak with banjo bolt connecting to the oil pipe? Since oil goes through there, it looks like it can leak very easily around aluminum/copper rings.
I replaced mine right before winter. I don't remember having an option for copper or aluminum, but I think mine were copper. There is no glue needed. Because of the tight fit under the intake manifold, I wasn't able to torque the lower side to spec, but the fitments haven't leaked at all. Still annoyed by how much that thing cost, though.
Here are some images from a post of mine, which has since vanished somehow, regarding that banjo bolt hidden under the intake and how to get to it with socket extensions:
1995 525i 5-Speed 201,000mi
