Thread: General engine overhaul procedures
    Default General engine overhaul procedures
    May 2006
    NH
    I saw no mention specifically of the M60. I had been left with the impression the M60 would not be suitable for such refurbishing. Are you aware whether this is true or if I were inclined might it be possible to refresh the M60B40 in my 540 which is now consuiming a quart of 5w30 in under 1k mies? New rings, crank shaft and connecting rod bearings and valve seal/guides just where ever oil may now be passing.
    1995 540i Manual build 1/95
    when that repair book was printed, probably the M60 engine was not yet on the market. There is no reason that an M60 engine is not suitable for refursbishing.
    Buy a Bentley Repair Manual, that covers it.
    oil consumption has many reasons. First of all I would check the typical fault
    see under engine OSV replacement = oil separator valve
    http://www.e38.org/
    Sep 2007
    Seattle, WA
    Quote Originally Posted by Jehu View Post
    You can easily do new rings/seals/bearings/etc in an M60. What you can't easily do is bore out the cylinders. So if you have a nik block that has cylinder wall damage you'd need to install sleeves in the cylinders in order to fix that as you can't just overbore it and re-ring it to match the new bore.
    Thanks Erich
    When rebuilding an engine, I see it says "Use a centre-punch or numberstamping dies to mark the main bearing caps to ensure refitting in their original locations on the block".
    Is this true? When I dismantled my old engine (bottom end), I did not mark anything. Will this matter if I ever want to re-assemble it?
    Feb 2007
    How about this for the M60, page 2 has some good pics:
    http://forums.bimmerforums.com/forum....php?t=1354664
    And this one looks pretty good too:
    http://forums.bimmerforums.com/forum...php?p=18483772
    Doesn't cover the engine internals but seems like a good place to start.
  1. General Module removal procedures
    By bsell in forum 5 Series BMW
    Last Post: 01-01-2010, 10:31 AM
  2. OT General Engine / Exhaust Smell
    By e34m30SF in forum 5 Series BMW
    Last Post: 06-05-2008, 02:05 PM
  3. V12 top of engine, gaskets, seals + parts overhaul
    Last Post: 12-19-2006, 04:52 AM
  4. Jacking Procedures
    Last Post: 11-11-2006, 12:01 PM
  5. Replies: 8
    Last Post: 07-24-2005, 02:23 PM
