Results 1 to 5 of 5
Thread: MPG Gauge not working??
    Unregistered Guest
    Default MPG Gauge not working??
    Hi,
    I have a E34 520ise 1990.
    Recently the MPG Gauge has stopped working. Everything else on the instrument cluster (speedo, gauges etc) are working fine.
    I can't seem to find what exactly sends a signal to the MPG gauge?
    Can anyone help??
    The MPG gauge twitches when I turn off the car so I'm guessing it's not the gauge that's dead but whatever it is that sends the signal.
    I heard that if the SI backup batteries in the instrument cluster are dead this can cause problems but I've checked those and they're fine.
    Can anyone give me a clue as to what controls the MPG gauge??
    Any help much appreciated,
    Mike.
    Nov 2004
    Washington
    Default mpg gauge
    I have the same problem. I'm starting to think maybe it's vacuum related...a hose in the engine compartment that's not connected? I've looked and found nothing. Have you found the solution to this problem? Let me know.
    Wellington,New Zealand
    Default Not a simple vacumn gauge
    I thought maybe it was too,but Bill R told me it gets its signal from the dme,maybe that capacitors would be a good place to start
    Gone but not forgotten
    Nov 2004
    Washington
    Default Thanks for the quick responce
    I'll work on fixing that, are these the ones I need to replace from this website? http://www.bmwe34.net/e34main/Mainte...Capacitors.htm
    Thanks.
    Default yes
    I dont know if that will do the trick.....
  1. 89 E34 gauge issue- intermittent working
    By E34inFlorida in forum 5 Series BMW
    Last Post: 12-22-2005, 10:29 AM
  2. how do you like my new gas gauge?
    By billb in forum 3 Series BMW
    Last Post: 12-16-2005, 07:24 AM
  3. Temperature gauge not working
    By franks in forum 5 Series BMW
    Last Post: 04-27-2005, 01:55 AM
  4. mph gauge
    By 1000_eyez in forum 5 Series BMW
    Last Post: 11-06-2004, 01:27 PM
  5. fuel gauge reading incorrectly, working incorrectly....
    Last Post: 06-27-2004, 12:23 AM
