Results 1 to 5 of 5
Thread: Aux Cooling Fan troubleshoot?
    May 2006
    NH
    Default Aux Cooling Fan troubleshoot?
    I was greeted the other day by myaproximately One year old Made in Germany Aux Cooling Fan suddenly going at High RPM the moment I turned the Key to Position #2 when about to start the car. The air temp at the time wasn't even 90 F.
    I removed the radiator sensor plug to jumper and see what was up. I got High but no low rpm.. when I jumper the Low wire I hear the Relay clicking but the Fan doesn't spin. Is the Resistor failed? I actualy went and bought a brand new relay from BMW but may not have needed it. The wires in the relay box leading to the low speed relay all appear intact but I haven't used a volt meter or ohm meter to check anything . oh and the two fuses are OK. Any ideas?
    1995 540i Manual build 1/95
    Apr 2008
    Illinois
    Quote Originally Posted by Jehu View Post
    Yeah, it's possible! Check the Resistor and the low speed supply.
    Honolulu
    Got a meter?
    check to see if the resistor is fried... Had the same thing a while back and it made me for a day trying to figure it out
    May 2006
    NH
    Thanks gents. I can get a meter and may be just source a replacement resistor and splice it in and see anyway.
    Feb 2007
    GreenHills East-Philippines
    had a similar problem too 2 weeks ago turned out to be the socket of the aux fan was not making contact so i cleaned it. Was brittle too and whenever the fan turns high mode socket becomes abnormally hot so im looking for a replacement socket.
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
  1. How do you troubleshoot a ticking valve
    Last Post: 06-11-2010, 11:54 AM
  2. Cluster wow's help to troubleshoot
    By nariusb in forum 5 Series BMW
    Last Post: 12-09-2005, 10:58 AM
  3. Troubleshoot this!
    By NielsGalan in forum 5 Series BMW
    Last Post: 12-06-2005, 03:32 PM
  4. Over Cooling
    By doogie in forum 5 Series BMW
    Last Post: 12-09-2004, 05:18 PM
  5. over cooling?
    Last Post: 12-04-2004, 02:46 AM
