Thread: Interior light
    Aug 2007
    New Zealand
    Default Interior light
    I have replaced my doorlocking mechanism, and in the course of doing this my interior lights have stopped working when I open the door and enter the car. The light next to the sunroof switch still works when I switch it manually.
    I have checked the fuses and they are OK.
    Where is the door trigger for the interior lights?
    Any Ideas?
    Oldham, England
    The door switch is in the striker plate on the door post. If you have to delve deeper this thread may be interest:
    http://www.bimmernut.com/forum/showt...interior+light
    Aug 2007
    New Zealand
    Thanks, That link looks very helpful I'll look into it today and report back.
    Aug 2007
    New Zealand
    I have read the link and determined that it is not a fuse, or the microswitch because the problem exists no matter which door is open, and the fuses check out for continuity.
    The appropriate relay in the RM clicks when power is applied, so I am starting to think it may be in the general module. ( I hope I am wrong).
    That is about it so far, I am open to any other input that may help solve the issue.
    Is Javier still around? he seems to have a great knowledge of the electrical system.
    Wellington,New Zealand
    Quote Originally Posted by Grantus View Post
    Last Activity: 06-08-2009 05:27 AM
    Gone but not forgotten
    Have you pulling the Light Kontrol Module in the fusebox? It is often a culprit, I think for example it 'kontrols' the courtesy light fade delay. You can troubleshoot the LKM with the wiring diagram for your car's VIN, but u can also swap round round with another known good LKM...
  1. interior light dimmer - new production
    Last Post: 12-12-2012, 06:28 PM
  2. repair of interior light switch
    Last Post: 06-28-2010, 04:38 PM
  3. If you have a light gray interior...
    By Robert K in forum 5 Series BMW
    Last Post: 12-05-2008, 11:23 PM
  4. Soft On/Off Interior Light Retrofit
    By Jr ///M5 in forum 5 Series BMW
    Last Post: 11-25-2008, 09:44 PM
  5. Interior light problem
    By drum2430 in forum 5 Series BMW
    Last Post: 01-07-2005, 09:05 AM
