Results 1 to 10 of 12
Thread: How hard job is it to replace oil pan upper gasket in M60?
    Apr 2008
    Illinois
    Default How hard job is it to replace oil pan upper gasket in M60?
    I am considering switching to Addinol synthetic oil and thought to my self it is a good idea to replace the pan gaskets after 180K on the upper one and 50k on the lower one.
    Is it straight forward job or will it involve specific tricks?
    Thanks guys!
    If it is not leaking, it won't leak. If you do happen to drop the pan, then tighten up that oil pump while you are at it. Common to find those bolts loose.
    East Brunswick, New Jersey
    I bought both gaskets but installed only the lower one even with the engine removed on the stand. The lower gasket is metal. The upper paper.
    Don't think it can be done easily in car. Look at what your are faced with.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Feb 2007
    Quote Originally Posted by yaofeng View Post
    Wow, any more pics? Where are the oil pump bolts you are supposed to tighten? Are they in that pic?
    This is the oil pan of the engine I scrapped.
    Then I bought this 66k M60B40 for $800 and change. The oil pan,
    Still I removed the oil pump. Took it apart and loctited all eleven M6 bolts.
    The 6 speed drive train is now on my 94 540it after my daughter wrecked the converted 95 540i in March, '09 in snow.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Apr 2008
    Illinois
    Thanks guys for your feedbacks. The leaking source is the O-Ring that seals oil leveling switch, I also noticed very light oil remnants on the upper gasket but it's not leaking. I thought it would be a good idea to replace both gaskets as I am switching to synthetic oil. Now I'd definitly check the oil pump bolts.
    Thanks for the pictures!
    You will also want to set the freeplay on the oil pump chain.
    Quote Originally Posted by bimmo_2007 View Post
    Sep 2005
    Central Coast, CA
    not to be rude but that oil looks like crap!
    how old is it? how often do you change it? Dino or Syn?
    Then again it could just be the lighting...
    Love the detailed pics though...great job man!!!
    http://www.bimmernut.com/forum/image.php?type=sigpic&userid=3314&dateline=1239168  877
    Jan 2008
    Sweden
    Agreed, awesome pics!
    Apr 2008
    Illinois
    Hmmmmm, is it something differrent from tightening the oil pump bolts? is there any specific procedure to set that free play or is it just about tightenig.
  1. Replace upper arm ball joints - possible?
    By E34-520iSE in forum 5 Series BMW
    Last Post: 01-24-2010, 04:42 PM
  2. Replies: 8
    Last Post: 11-19-2007, 03:25 PM
  3. E32 M70 upper oil pan gasket replacement
    Last Post: 04-19-2007, 05:02 AM
  4. Upper Timing cover gasket in M60
    Last Post: 11-08-2006, 03:50 PM
  5. Boot on upper thrust arm is broken- Replace?
    Last Post: 06-19-2004, 12:56 PM
