Originally Posted by
BennyM
With a little help from Triton540i, I pressed M5 bushings into the Meyle HD arms and installed my worn out arms yesterday. The highway shimmy is 95% gone and the brake shimmy and low speed clunk are gone. BTW, my impact hammer and tie rod puller kit are the best $160 bucks I ever spent. The toughest bolts and ball joints have no chance against my wrath.
QUESTION: I understand the critical load factor, but how significant is the torque? My only concern is that I wasn't able to torque the bushings to the full 94 ft/lbs as I didn't have enough room under the car for proper leverage. I got them torqued (yes under load) to 80 ft/lbs. I'm a stickler for following spec, but I just couldn't get them any tighter and had to get to a meeting.
BennyM
Benny, go in and re-torque them soon as you can. They are tight right now but as time goes on there is a big chance that the interference fit will get loose. You can get play between the bolt and the hole which will result in a small amount of play. As this goes on there will be wear in the taper fit of the hole and for one you wont be able to unscrew the nut and also a new arm bolt will never tighten correctly because the taper is wasted.
