Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Help...!!! ZF-5HP30 has no reverse.
    Apr 2005
    The Bronx, NY
    Quote Originally Posted by whiskychaser View Post
    Just to cheer you up on the drive to the garage:
    Yike !!!
    Anyway, many thanks for the picture. I will do the system reset tomorrow...just to rule out the computerized control part.
    I made an appointment w/ my indy on this Friday. As I thought, he suggested to drop the pan to see "how bad" is the damage. Then, will go from there. He said the worst case is to replace the tranny & the best case is just replace the valve body unit.
    Let's see...
    '95 BMW-540i/Auto (ZF-5HP30)...NO reverse
    "Original" Nikasil block (+ Fristo Lays Chip)
    87+ K Miles
    Apr 2005
    The Bronx, NY
    System reset yesterday just help smoothing the ideling, but it did not fix my "no reverse" issue.
    This morning, crawling to my indy garrage (about 3.5 miles) on a less than 20 MpH speed (& put the gear in neutral position at every traffic light...I don't know if it helps or hurts?).
    Moment of the truth...
    After dropped the pan, not much "lifetime" fluid ~2 Qt. or less (...is this a normal vol. we expect?) came out from the drain plug. The "lifetime" fuild is quite thick, no burning smell. The color is dark red, but clear. The filter is warping a bit out of shape. There is a few metal dusts on the magnets. The best is...no piece of metal in the pan.
    Here are my options:
    a. Replace only the valve body (+ filter, O-ring & gasket + tranny fluid/diff)...$550 & no warranty if it will fix the no reverse issue.
    b. Rebuilt the tranny (+ filter/O-ring/gasket + tranny fluid/diff) & replace the rear main/crank seal (since the tranny has to be detached)...$2100 & w/ 12 months (or 12K miles) "no out of pocket" warranty.
    Yeah, I decided to get the last one for the peace of mind....$2100 !!!
    Hopefully, it will prolong the life my 540i for another 2-3 yrs.
    87+ K Miles
    Seems like low fluid level... I would have filled it up to spec to see if that solves the reverse problem.
    Then I'd opt for A... which is part of B so if A failed then B to go and just pay the additional to $2100. No big deal.
    Personally, I think all you need is A because of your super low mileage.
    Jun 2006
    Wisconsin
    If you're still looking for a shop in NY, you might want to read this thread on the state BMWCCA chapter's Web forum: http://nybmwcca.org/forums/index.php?showtopic=111
  1. 5HP30 Dipstick
    By MBXB in forum 5 Series BMW
    Last Post: 09-01-2010, 08:15 PM
  2. 5HP30 ATF Substitute
    Last Post: 03-06-2010, 11:46 AM
  3. 5HP30 Problem
    By Tiger in forum 5 Series BMW
    Last Post: 05-12-2008, 06:55 PM
  4. 5HP30 question
    By charlie in forum 5 Series BMW
    Last Post: 03-03-2008, 05:42 AM
  5. 5hp30
    By Ollie in forum 5 Series BMW
    Last Post: 03-20-2004, 08:20 AM
Tags for this Thread
