Results 1 to 3 of 3
Thread: M60 Rough idle, blue smoke puff on startup
    Apr 2008
    Illinois
    Default M60 Rough idle, blue smoke puff on startup
    Good day fellas,
    Recently, my 540 engine developed a rough idle, it also blew blue smoke puff on startup for just a second, I sprayed some carb cleaner on the intake manifold to test for intake leaks but the idle didn't change. However, when I pulled the dipstick nothing changed too but if I put my finger on the dipstick hole I can feel air suction through it. The idle is steady at 500 RPM.
    Any suggestions?
    Ahmed
    90% of the time of rough idle is the crank ventilation valve... which is a major bear to work on.
    You need to pull the spark plug to see if there is abnormal indications.
    You could have a leaky injector.
    Apr 2008
    Illinois
    Is it the oil seperator valve OSV? hmmmmmm well that make sense.
    I already pulled the spark plugs out, they looked good and nothing appeared abnormal.
    Today, the blue smoke puff at startup disappered. But I was wondering if the O2 sensor could cause a rough idle. I noticed that exhaust smelled rich.
  1. 540i/6 puff of smoke start up
    By dog man in forum 5 Series BMW
    Last Post: 06-04-2008, 12:52 PM
  2. M60 3L rough idle , white smoke at start ,and more problems
    By Brent in NZ hartge 535i in forum 7 Series BMW
    Last Post: 04-08-2005, 11:07 PM
  3. M60 3L rough idle , white smoke at start ,and more problems
    By Brent in NZ hartge 535i in forum 5 Series BMW
    Last Post: 04-08-2005, 10:52 AM
  4. White cloud and rough idle at startup.
    By NielsGalan in forum 5 Series BMW
    Last Post: 10-04-2004, 02:43 PM
  5. 95 540i - puff of smoke on start up
    By Rick in forum Engine & Drivetrain
    Last Post: 07-05-2004, 02:55 PM
