Results 1 to 9 of 9
Thread: No engine start after sitting for 2 1/2 months
    Aug 2006
    Houston
    Default No engine start after sitting for 2 1/2 months
    I had to save up some money to be able to replace my fan clutch [2nd time in 2 years ] I was going to test to see if the new one worked right or not and the engine would not turn over
    I set a trickle charge on the battery for a few hours and got some promising sounds out from the car, but still would not start
    Anything special I should look at or do to make sure I get it started up right after sitting for a long time? Just want to make sure I dont do anything to harm the engine. Just finished paying off the lil bit I had left on the loan for the car too >.<
    [Been a while since ive been on! but that is just because I have not had any problems with the old gal!]
    BTW Gale... Love your version of seat twist fix that was posted! made things so much easier Might add, with a S2 (I think IIRC) bit and a cordless drill you can move the motor with that to make ti align up easier if your seat is really out of sync with the other side
    Sep 2007
    Seattle, WA
    The battery might be dead for good. You already know it ran down to dead as it wouldn't do anything when you tried to start it.
    How old is the battery? What brand & size is it?
    Being how it's that dead you'll want to let it trickle charge at least overnight, 24 hours would be better.
    If I was you I might want to pour a little oil down the fill and down the filter canister as well before you try to start it.
    Aug 2006
    Houston
    I will check in the morning, I had posted this right before I left for work, I am going to drain as many fluids as I can before giving it another try tomorrow.
    Transmission I gotta drop the pan correct?
    Apr 2008
    Belgium
    I have let my E34 and E30 sit doing nothing for more 3 months.
    but instead I have always disconnected the battery. Always always do that, even if you battery is supposed to survive it. it is just a waste of battery life otherwise.
    and I have never had trouble starting after a long sleep.
    trickle charge over 24 hours or replace.
    it will be easier to work from there.
    Jan 2007
    Dayton Ohio
    I agree, pull the battery and have it checked at a parts house. Autozone etc. They do this for free.
    Sep 2007
    Seattle, WA
    Quote Originally Posted by Milkboot View Post
    Should be absolutely no reason to drain any fluids. Like I said I'd pour a little fresh oil down the fill and filter just so it's not a fully dry start.
    Aug 2006
    Houston
    Well, one new battery and some swapping of relays and about 2 hours of guessing got her started right up! Snakeyes and I noticed that the fuel pump was not coming on and I always get a stomp test code for the fuel pump relay [even tho it was changed out the first time I saw it] So we figured what the hell, start swaping them out, and TADA, she lives!
    Was a little scary at first with the Trans Program warning coming up on the dash, but after we tightend down the battery and tried her once more and drove to put some gas in the tank, there was no longer the message [whew?]
    Thanks for the help guys!
    Jan 2007
    Dayton Ohio
    Default Another success
    Another success. These are some amazing machines
    Low voltage will trigger tons of errors... even on newer cars.
  1. Hard to Start after sitting a few hours
    Last Post: 10-16-2008, 08:40 AM
  2. Why engine won't start sometimes??
    By romus in forum 5 Series BMW
    Last Post: 11-09-2005, 04:58 AM
  3. Engine won't start/run
    By Yoakim in forum 5 Series BMW
    Last Post: 10-28-2004, 04:47 AM
  4. Replies: 6
    Last Post: 10-10-2004, 03:49 PM
  5. Engine Won't Start
    By CJK525iT in forum 5 Series BMW
    Last Post: 08-18-2004, 11:26 PM
