Results 1 to 8 of 8
Thread: Pulling my engines
    Jul 2005
    Metuchen NJ USA
    Default Pulling my engines
    I'm putting an automatic engine in a manual trans car. The engine has 115,000 miles on it and ran good. Since it's going to be out I going to replace the water pump, intake gaskets and any other gaskets and vacuum system parts as I can before it goes in. While it's out is there anything else I should be looking for on the engine or the engine bay. I don't want to mess this up by missing something I could have taken care of.
    all hoses, belts thermostat etc. Done once and good for another hundy miles. Plugs wires, cap/rotor and related are worth looking at while out too.
    Oldham, England
    Sump gasket if its weeping? Piece of cake with the engine out. Not so with it in situ
    old vacume hoses maybe
    Don't forget a pilot bearing for the manual trans' input shaft.
    Any hydraulic lines that are a bitch to get at?
    East Brunswick, New Jersey
    Front and rear main seals. Loctite the flywheel bolts or your rear main seal replacement will be for naught.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Austin
    If your windshield wipers acted like they were hitting the hood, you can fix this easily with no engine in the way.
    Quote Originally Posted by Elekta View Post
    This is a *#@%ing GREAT idea and should be standard procedure on every old E34 with an engine out.
  1. I was pulling fuses..
    By mzarifkar in forum 5 Series BMW
    Last Post: 04-27-2007, 08:19 AM
  2. the car is pulling a little right
    By paschalisg in forum Suspension & Steering
    Last Post: 03-13-2005, 07:29 AM
  3. the car is pulling a little right
    By paschalisg in forum 5 Series BMW
  4. car pulling...even after alignment.
    Last Post: 03-05-2005, 01:26 PM
  5. Pulling to the left
    By jj7 in forum 5 Series BMW
    Last Post: 10-23-2004, 05:32 PM
