My son, Sean just bought a nice 2000 323ci coupe with 69,000 miles on it. The windshield washer is not spraying fluid and you cannot hear the motor running so I suspect it is a fuse. Not being familiar with the car yet I don't readily see where the fuse box is located. Any help would be appreciated.
Al Gray
I located the fuses and checked all of them for the windshield washer pump, 49, 52, and 59. None were burned out. I can only conclude that either the washer pump is bad ($37.95 cost) or perhaps the switch is bad in the stalk that opertates the windshield wipers. The wipers work fine but when you pull back on the stalk to actuate the windshield wiper fluid nothing happens. I tend to think that on a 10 year old car most likely a $38 dollar pump would fail. How could I check it to make sure?
Al Gray
Al,
Check the connector to the washer pump. Make sure it's not loose or corroded. Then check the wire leads with multimeter. Make sure you are getting voltage to the pump. If you're getting votlage and pump doesn't work, pump is bad. If no voltage, check the relay # 4 in electronic box on the rear left side of engine compartment. Relay #4 is the far rear relay. Swap it with Relay # 9 (back-up light) which is located far forward to test if relay is bad or not. I doubt the switch is bad but is a possible.
Good luck,
Rick
RICK
BMW 1995 525i (Alpine White)
RICK
