So, I took out the trunk button assembly to clean and grease it and when I put it back together, I still had a tiny spring and a super tiny ball bearing on my work table. Can anyone remember where those two miniscule items go? The button seems to work fine without them, but I'm sure there's a good reason for these little pieces.
Is this the ball and spring, from inside the lockbarrel?
Actually the pic is of a front door lock barrel thats why the proportions are mismatched Did you take the lock apart? If you did the spring and ball goes inside the barrel in a similar position!
Check this for hints: http://evansweb.info/articles/2003/0...el-replacement.
If you didnīt take the lock apart Iīm bewildered too..
my goodness I thought you were talking about the trunk key lock, no wonder I had no idea what this was...
If you take something apart enough times, pretty soon you'll have enough left over parts to make 2 of them.
gale
