Results 1 to 5 of 5
Thread: Staked U-joint Driveshaft Rebuild
    Default Staked U-joint Driveshaft Rebuild
    http://mysite.verizon.net/vzerdcib/e34a/id9.html
    special thanks to Rustam, great write up and pics.
    yes mate the same link is here
    Sep 2007
    Michigan
    How about a part number for the replacement u joint and the retaining clip? I always wondered about this. Think it would work on an e30 M3?
    see ETK what is available from BMW, and the spezialized driveline shops like
    https://www.drivetrain.com/parts_catalog/drivetrain/
    http://www.shaftpro.com/
    http://www.machineservice.com/driveline-parts.htm
    found on google, no affiliation.
    But remember, often a rebalancing is required, so for sure it is easier to send it to a repair shop with the proper equipment to do so.
    http://bmwe32.masscom.net/sean750/dr...driveshaft.htm
    SPECIALITY UNIVERSAL JOINTS
    Replacement U-Joints for Staked-In Style Driveshafts
    http://www.rockforddriveline.com/Staked%20Ujoints.PDF
    BMW
    1989-93 BMW 535i 430-11
    1987-92 BMW 735i 430-11
    1993-94 BMW 740i 430-12A
    1993-94 BMW 740iL 430-12A
    1988-94 BMW 750i 430-11
    1991-94 BMW M5 430-11
    Rockford Drive Line
    The Solution Company
    1500 11th Ave
    Rockford, IL 61104
    Ph. 815-962-1411 - Fax 815-965-4857
    Sep 2007
    Michigan
    So I should be glad I have a manual transmission and only one staked u joint?
  1. Staked u-joint on a manual tranny
    Last Post: 08-25-2010, 07:15 PM
  2. Is there a CV joint on the end of my driveshaft?
    Last Post: 06-22-2010, 05:10 AM
  3. Driveshaft/u-joint question
    By cableface in forum 5 Series BMW
    Last Post: 12-21-2006, 10:02 AM
  4. Replies: 4
    Last Post: 11-12-2005, 09:55 AM
  5. Possible driveshaft/U-joint problem
    By Al Gray in forum 5 Series BMW
    Last Post: 02-23-2005, 01:04 PM
