Results 1 to 5 of 5
Thread: jumping the starter on a m20b25
    Sep 2007
    Michigan
    Default jumping the starter on a m20b25
    Good Morning,
    I just put the motor and trans back in, getting ready to fire it up and wanted to crank it over a few times to build oil pressure. The starter only operates 1 in 10 times and only when it feels like it. Is there a jumper wire process to use to verify that the starter didn't get toasted?
    The small blk/yellow wire is the solenoid terminal. run a jumper to 12v to bypass the switch.
    Sep 2007
    Michigan
    Hi Ross,
    Tried that and got nothing. Is the solenoid toasted?
    Can one purchase a solenoid separately? Or is a used starter the way to go?
    PA
    solenoid toast or no ground to the starter.
    Sep 2007
    Michigan
    I cleaned the ground strap between the solenoid and starter. I did paint the starter a nice shiny black. Did I compromise my ground by doing that?
  1. E34 Manual Gearbox - jumping out of first gear
    By jasrob in forum 5 Series BMW
    Last Post: 11-28-2007, 03:12 AM
  2. E30 m20b25 engine into my e34
    By meinE34 in forum 5 Series BMW
    Last Post: 10-04-2006, 12:06 AM
  3. Speedometer jumping....
    By JD525IA in forum 5 Series BMW
    Last Post: 05-02-2006, 12:37 PM
  4. jumping speedo-meter
    By TWISM in forum 5 Series BMW
    Last Post: 04-14-2006, 06:44 PM
  5. Jumping out of 4th?!!?
    By funkmaster in forum 5 Series BMW
    Last Post: 01-30-2005, 11:43 PM
