Thread: Digital Temperature gauge
    Jun 2008
    south africa
    Default Digital Temperature gauge
    hi
    yesterday i noticed the digital temperature gauge was flashing at 30.0 and it was so cold. how will i get the gauge to show the correct temp.i only know how to set the date and time.
    1 .what could cause the temp. to show the wrong reading and how do i solve this problem.
    thanks
    St. Louis
    Quote Originally Posted by allerston View Post
    hi
    thanks
    Perhaps I miss understood your question, but here is what I gather.
    Judging from your signature, you are not in the US. Your computer is probably set to Fahrenheit, not Celsius. 30 degrees F is cold (i guess it is all subjective), right about 0 deg C.
    There is a C/F & Km/Miles button on the top, left of the display, on the computer itself.
    L.
    1995 525iA 200,000 Miles
    Jun 2008
    south africa
    Quote Originally Posted by Luftpost View Post
    L.
    at the moment south africa is very cold .
    30 degrees celsius is on the gauge
    St. Louis
    I am not sure where the temp sensor is for computer. Does everything else on it work properly?
    I am curious what the flashing 30 is about. I will look in my owners manual.
    Perhaps someone else can chime in....
    L
    owners manual, black ice warning at 3 degree Celsius.
    hi
    thanks
    Wrong temp reading is usually caused by a bad connection at the sensor in the grill. Clean the contacts and use an electronic cleaner you should be good to go.
  1. Temperature gauge not reading right
    By Eagle in forum 5 Series BMW
    Last Post: 03-14-2008, 07:32 AM
  2. Replies: 9
    Last Post: 03-04-2007, 09:58 AM
  3. Temperature gauge sticks at start-up
    By JMI in forum 5 Series BMW
    Last Post: 05-03-2006, 11:17 AM
  4. Odd behavior from temperature gauge
    By Guapo in forum 5 Series BMW
    Last Post: 12-25-2005, 03:49 PM
  5. Temperature gauge not working
    By franks in forum 5 Series BMW
    Last Post: 04-27-2005, 01:55 AM
