Do let us know. I am getting ready for something similar.....
L
After putting up for 2-3 years with all sorts of sounds and knocks, I am finally getting the front end rebuilt. This will include strut inserts, shock mounts, upper and lower control arms and bushings/joints, bumps stops as well as the rear pitman arms. I will post later what the difference is after a 600 miles drive this weekend but I imagine the steering wheel 55 mph wobble will be gone and the confidence in the car will be back! Am also getting a front end alignment the same day so I do not screw anything up after all this work.
L
1995 525iA 200,000 Miles
Mechanic says he will only replace only what is necessary and there is no restocking fee for unused parts which is sweet. We have worked out a price and it can only go down which is a nice deal. I am just too busy every weekend from now until late Nov. in Chicago which is why I am not attempting the work myself. And by then a concrete floor in an unheated garage in Chicago is not a nice place to be!
Thanks for the heads up though!
Here is a breakdown of the work I had done on the car last week. The following items were replaced:
1. Replace all tie rod ends
2. Replace upper control arms and bushings
3. Replace lower control arms and bushings
4. Replace strut inserts
5. Replace bump stops, dust sleeves, shock mounts
6. Replace rear pitman arms and bolts
7. Front end alignment
8. Replace fuel filter
The work was all done at a local mechanic as I did not want any surprises in my garage while doing the work myself. Took the car out for a 500 mile drive last weekend and all I can say is what a difference!!! No more shimmy at 55-60 mph. No more wandering steering. Car tracks true and straight and responds to even the slightest steering wheel input. I suggest this repair for anyone who plans on keeping their vehicle for any amount of time. We also adjusted the steering box allen key bolt to tighten up the steering and this does make a difference in input when driving. There will still a bit of play in the wheel at park or in neutral but when you are driving the difference is noticeable. Just do not over tighten as you will get the gears inside too close together and wear out the gear teeth.
Like I said if you are keeping your car like I plan on doing it is a worthwhile investment. Total cost of parts and repair was $2000.00 even but well worth the peace of mind when I am driving around. No more funny noises and rattles and much improved steering input.
Ahh sway bar links were replaced last year.
