Thread: How can I tow 535i with jammed ignition switch?
    Near San Francisco, CA, USA
    Default How can I tow 535i with jammed ignition switch?
    My shop Bavarian Professionals of Berkeley, CA are willing and able to fix my jammed ignition switch, and I want to tow the car to them.
    But the car is in a side-by-side parking space, only 1.5Ft from a wall, with a sharp, backing turn required for removal. Because the steering wheel is locked, I don't see how the car can be positioned so it can be loaded onto the tow truck?
    Any suggestions? 1989 535i manual 240K professionally maintained and running/driving like new except for this.
    Benneton (United Colors of)
    any tow company that does repos/parking violations will have little hydraulic dollies that they can put under your wheels to move the car. just tell the towing company that the steering is immobile and the specifics of your parking situation before they dispatch a truck.
    oh, and just in case your wheels are turned at angles, you might want to ask for a flatbed. your choice.
    Default Very helpful Ryan
    Quote Originally Posted by ryan roopnarine View Post
    Now I can proceed with confidence!
    Jun 2005
    Cheshire, UK
    With a lot of patience, rocking of the steering wheel, tapping of the lock (if you can get to it) and copious amounts of swearing you may be able to get the barrel to un-seize for long enough to start the car. Then drive it straight to the shop.
    I had the same problem with my e34 and could always manage to get it going before I received my new barrel - it took about 5 days from BMW.
    If the keys are original to the car, you can get a new ignition barrel cut to the key from BMW, you just need proof of title and the VIN number.
    HTH.
    1997 e39 523SEi touring.
  1. My ignition switch will only turn a 1/4 of the way
    By WILLIETOPZ in forum 5 Series BMW
    Last Post: 05-11-2007, 05:59 AM
  2. Ignition switch/key trouble
    By gale in forum 5 Series BMW
    Last Post: 03-20-2007, 11:15 PM
  3. Ignition switch/lock?
    By K_Po_Uno in forum 5 Series BMW
    Last Post: 03-12-2005, 12:45 AM
  4. jammed ignition
    By jackieleung61 in forum 5 Series BMW
    Last Post: 04-19-2004, 09:18 AM
  5. ignition switch, $550 later (ouch)
    By kjbcpa in forum 5 Series BMW
    Last Post: 03-25-2004, 12:39 PM
