Results 1 to 4 of 4
Thread: very high idle
    Jun 2008
    south africa
    Default very high idle
    hello people
    the idle on the car is 1500 rpm which i think is to high it used to be at 1000 rpm.My problem is, if its to high what do i do to bring it down .
    Weather the engine is cold or warmed up the idle still stays at 1500 rpm.
    before when i used to start the car 4 example in the morning the idle will be at 1500rpm and when the engine warms up the idle will go down to 1000 rpm
    thanks
    Remove the Idle Control Valve nad clean it with a rag and some light penetrating oil. Make sure it opens and closs smoothly and isn't jammed up with oil or otherwise faulty. Check for vacuum leaks, all the hoses and connections to the intake manfold need to be double checked, air getting in will cause a lot of weird behaviour...
    If an M50 engine (the dual overhead cam one), it is likely to need new gaskets around the valve cover and the spark plug recesses...
    Dec 2006
    thread resurrection, but what makes you say this?
  1. Still having high RPM and idle problems...
    By paanta in forum 5 Series BMW
    Last Post: 03-30-2009, 02:54 PM
  2. high fuel consumption/idle - solution
    Last Post: 01-26-2007, 10:44 AM
  3. Coolant leak and high idle temp.
    By DannyO in forum 5 Series BMW
    Last Post: 07-25-2006, 02:32 PM
  4. Extremely high idle.
    By Jeff-n-MT in forum 5 Series BMW
    Last Post: 06-28-2006, 08:51 AM
  5. Idle High
    By Wtrskigrl in forum 3 Series BMW
    Last Post: 12-19-2005, 08:36 AM
