Results 1 to 10 of 13
Thread: Door trim Fastner Pad
    St. Louis
    Default Door trim Fastner Pad
    Anyone have a source for these things? I need about 4 or 5 pcs.
    1995 525iA 200,000 Miles
    East Brunswick, New Jersey
    Is it not listed in ETK? Drop me a line if you cannot get them from the dealer. Good thing the junk collector in me saved the old door cards in the attic of my garage when I replaced them with wood trim ones.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    can you find any BMW part number on it? 7 or 11 digits
    Lexington, Kentucky
    Best find them off a 'dead' door panel as there are differenct pieces depending on door placement. I could not find a part number on them when i needed one. I got it through the kindness of someone on one of the BMW forums.
    St. Louis
    I have not had any luck with part numbers either (searched REALOEM). Sorry, but what is ETK?
    yaofeng-thanks, I may do that if I can't find them locally. I will let you know.
    L
    realoem is the online ETK = German for ErsatzTeilKatalog = spare parts catalogue.
    St. Louis
    Danke, I should know das. Ich spreche nemlich Deutsch.
    L.
    To further complicate this they are all different profiles to fit various positions on the door panel.
    Best to head off to a wrecker
    What glue do you use? I tried contac adhesive, it was nowhere near as good as the OE stuff- that is far more brittle and strong. I think a product we in Oz know as 'Liquid Nails' would be more successful. Has to deal with extreme heat as its is in a car. Liquid nails is a builder's adhesive, used to stick panels to wooden uprights and so forth... Let us know hoe you go...
    Houston, TX
    I used Gorilla Glue to re-attach mine and its been holding fine for more than a year so far, but I bet epoxy would do fine. Liquid nails probably would do the job, too - especially if you have an open tube handy. Super glue, perhaps?
  1. Door trim - gone.
    By Rustam in forum 5 Series BMW
    Last Post: 05-29-2006, 10:21 AM
  2. Door Trim
    Last Post: 02-08-2006, 04:45 AM
  3. Lower Door Trim
    By clhorton in forum 5 Series BMW
    Last Post: 01-19-2006, 03:31 PM
  4. Door trim panels
    By Chip in forum 5 Series BMW
    Last Post: 07-20-2004, 08:06 AM
