Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: I did it - rebuilt a 5hp24
    1/2 Way tween Chicago & Milwaukee
    Default I did it - rebuilt a 5hp24
    I did it, I did it. It even works. I rebuilt the 5hp24 in my 2001 740iL.
    I took my time and rebuilt it over many weekend over the summer. Wasn't in a hurry as it really is our winter driver.
    It has 155k miles on it, it really did not need a rebuild. The only symptom was a little bit of a shutter sometimes when shifting into second gear.
    I took the tranny apart, and found essentially no wear. The clutches looked fine, no torn seals, and even the reverse plunger had no chunks taken out of it as seen on other posts.
    It's actually an easy job, taking the tranny out, and putting it back in is the difficult part.
    Took my time, rebuilt a group/drum pack at a time, lined up the clutches, and it all snapped back together. I only replaced all the seals and clutches, that's it. I did not even open up the valve body. I figured I could always do that from under the car without having to pull the tranny.
    Here's a slideshow. The slideshow came out weird, you have to go backwards to see the forward progression. Oh well.
    http://bimmernut.com/5hp24show/
    A Bimmer Nut for sure: '04 530im (current daily driver), '97 m3, '98 323is, '99 Z3, '01 740iL, '06 330cicm zhp, '02 R1150R, '69 r60, Owner/Operator of www.Bimmer.info and www.BimmerNut.com
    And I still maintain: '90 535im (sold to daughters best friend, one of my favorite bimmers), '92 525im (daughters other best friend now drives this one).
    Benneton (United Colors of)
    Good for you. It is a nice feeling when you know that you accomplished something like that, despite people intoning at the outset that you are attempting brain surgery. Did you have to go back into it for any "seconds" afterward? You wouldn't be the first.
    Aug 2005
    Iowa, USA
    congratulations, If you would like more practice, you can do mine
    1995 525i "Stefanie"
    Oldham, England
    Impressed! Have only taken one apart to see where it failed. Were there any concerns about getting any endfloat within spec.?
    No seconds really. Just had to reinsert drums a couple times to get that last 1/4 inch click on aligning clutch disks.
    No more practice please, I like doing things like this one time, the second time it becomes "work".
    Now I want to rebuild an engine. I have not done the bottom end before. Done valve jobs, rebuild alternators, typical valley pans and oil separators. All the cooling stuff. I've done some a/c work never successful though with the a/c. I hate a/c stuff, I can fix it, but always leaks. When the a/c goes, I buy a new car.
    Australia
    Good work. I might try to do that to mine at some stage.
    Honolulu
    Good job!
    Where did you pick up the kit from?
    I got the kit here:
    http://www.autotransparts.com/cart.p...t_detail&p=730
    End float, whats that? !!!!!!!!!!!!!!!!!!
    Thanks for the link! They got great prices and I bookmarked them.
    OK, end float, I found this so I know what you are talking about.
    http://www.bimmernut.com/forum/showt...ight=end+float
    Well, I'm hoping I don't have a problem. When I lined up the torque converter and tranny, I did have some problem with the TC binding on the flywheel, but I backed out the tranny and was able to to turn the torque converter, to get it to a point where things seem to fit together with no binding. Car is driving fine, so I am hopeful all is well.
  1. OT: VW Rebuilt Tranny Where to get em?
    Last Post: 05-11-2007, 09:33 PM
  2. rebuilt the oil pump
    By 632 Regal in forum 8 Series BMW
    Last Post: 12-16-2006, 11:52 PM
  3. Looking for new or rebuilt AC compressor.....
    By Bellicose Right Winger in forum 5 Series BMW
    Last Post: 05-16-2006, 08:16 PM
