all in here http://bmwfans.info/
or here, weights of engines
http://www.bimmerforums.com/engine_faq/
I dont imagine you are going to send it loose So can I suggest you make the shipping company aware of the gross weight (net + packaging) and the dimensions of the package. You dont want a price hike after it has been picked up. Also have a think about insurance in case they lose it or break it
I assume with all the attachments - not clear what you mean by complete - like alternator, starter, intake, throttle valve etc pp it will be close to 300 kgs.
the small things make a big difference
-engine oil ?
alternator 7 kg
starter motor 4.5 kg
oil filter 1.5 kg
ignition wires 1.2 kg
distributor 0.6 kg
ignition coil 0.7 kg
fan clutch 1.0 kg
intake 6.5 kg
exhaust manifolds 6.4 kg
fan blade 0.7 kg
coolant hoses?
that you could get or not, but with 300 you are on the save side.
I have a crated M30 with all the accessories in other words the full engine minus the oil and it weighed out 345 pounds. Hope this helps
