Dont have a pic but mine looks same except I dont have the damper in the diagram
I have had an ongoing vibration in my car that is kind of a pain in the arse. At 60 mph (sometimes 55-65) the car has a vibration in that can be felt in the driveshaft tunnel fading towards the rear of the car. Sometimes it is very violent and sometimes its smooth as if nothing is wrong. I thought that maybe i had a wheel out of balance, but I put my oem 15" 60 series tires back on and the vibration is not as bad, but is still very noticeable. Was wondering if anyone had run across this problem.
My guibo disc and bolts were replaced 15k miles ago, center driveshaft bearing 15k ago.
Logged onto realoem to see what bushings could have worn out in the rearend linkage, and saw that there is a vibration dampner that apparently goes over the guibo disc.
vibration dampner
V
http://www.realoem.com/bmw/showparts...34&hg=26&fg=10
Tickin' Red Bomb
sure it isnt THE shimmy?
Gone but not forgotten
You know... it really sounds like thrust arm bushing is bad... when you tap on the brake at that speed... does it worsen?
Rotate tires around and see what happens.
That vibration dampener is pretty much worthless. Most get discarded when the Guibo is done the first time. I've spoken to a well regarded driveshaft builder who told me that if the shaft is missing it when the core comes in they don't bother with replacing it. Unless it is in place and falling apart causing an imbalance I would discount the dampener.
Center bearing support maybe, but usually you get a low speed thumping also.
