I can only guess shock and shock mount. Possibly bad spring pad that cause metal to metal contact.
I posted last month about a booming or banging noise that I have been hearing from the right rear of the car when I ride over bumps in the road. I had the entire suspension checked out by a mechanic I trust, as well as the rear subframe mounts, and everything was fine with the exception of a ball joint, which I had replaced.
The noise is somewhat lessened now, but it is still there. What else could be loose or banging around back there when I go over a bump? It is a bushing issue perhaps, something that could be missed when doing a suspension check? There is no metallic aspect to the sound at all.
Did you cut down the shock bumper?
I had this as the source of a major PITA noise once and once I made sure it was all tightened up back there the noise went away.
Yep, bumpstop
