Hi Shaughan
I know that you have the Citroen. I also have one, one of the last produced 2CV Charleston with only 1.200 km on the clock. Bought new and put into my shack.
But that is another story.
20 years so far and still doing o.k. That means about 160.000 kms driven on excellent roads.
cannot be recharged, I checked that because I know the Citroen system. The one we cut off has on one side a spot weld, apparently they add there the gas and then close it
yes, but quite complicated, see the pics in above link from the German 7-forum.
http://www.7-forum.com/forum/24/komp...tml#post952281
You need some special equipment. We have discussed that in our group of DIYers, the best way to test a bomb is to push a screwdriver in (no worry there is the plastic piece) the hole where the connection for the hose goes. If you can push it in, it lost gas already = the inner sphere is leaking. If you cannot push the screwdriver in, the bomb is o.k.
The pressure inside is 23 Bar! Probbably you cannot push that in, I found that out in January 2009 in this thread
http://www.7-forum.com/forum/5/nivea...rt-105597.html
such a test is not necessary. If the gas is partly or all gone, all the space inside the bomb is filled with Pentosin, and the outer shell of the bomb is steel, nothing can escape = instead of gas is now Pentosin to fill the space. To find out a dead bomb in installed condition: the rear is dead hard, no suspension at all. Because the bombs are actually the dampers for the shocks.
If you run the engine that the rear is on correct level, and then the next morning it is down on the rear, there can be only 2 reasons:
1. the regulating valve is not set at zero point (or leaking) and lets Pentosin flow overnight from the rear to the engine room back. Easy check is to have a look into the Pentosin container when you stop the engine and another look next day when/before you start the engine. If more Pentosin, it comes from the rear thru the return line = regulating valve problem.
2. might be air in the system, but basically it bleeds itself in most of the system, but when there is air in the shocks, you must raise the rear that the shocks are extended, then the little bleeding valve at the bottom of the shock is bleeding. See pic in the German link.
