Here's what you need to do.....
To do it properly, the car needs to be level and sitting on its tyres. You can run it up on ramps, jack up the rear then drop it onto stacked blocks or ramps of the same height to get it level.
The car needs to be at spec ride height before you torque down the bolts. In addition to a full tank of gas, you need about 150 pounds in each front seat, 150 pounds in the middle of the back seat, and 45 pounds in the trunk. You can get the proper ride height measurements from your Bentley manual. Can't help you as I haven't got it at work!
You then torque down the bolt holding the bushing side of the thrust arm to the frame to 110Nm (81 ft-lb).
Done......
Originally Posted by
Kibokojoe
I am replacing the lower control and thrust arms. I know you have to load the front end before tightening the nuts and bolts, question is??? Can I leave the bolt/nuts loose and then drive it up on a pair of ramps and then tighten them or do I have to have the front and back end level? I suppose I could drive the car up on the ramps and then level the car using a jack and stands. Will that work? The other question is do I really have to load the fenders to the correct weight before I tighten or will the weight of the car suffice? Is this really that critical?
"Uncle" Phil C
2011 Kia Optima EX-P.
Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
03 R1150RT 6spd. "DaRTth"
00 R1100R 5spd. "LeRoy"
