Try a new nut, or a good wrap with teflon tape.
or
you can go Afro American engineering and put a hose clamp on the nut to compress it.
'89 525 new Baer rad prob w float level threads. Tighten "nut/cap" of coolant level sensor and something happens where "nut" goes over tight and threads "slip". Then threads re engage and tighten to original failure point.
Catch 22, TIGHTENING BY HAND. No way can I have confidence in so little torque holding 15 psi.
Old radiator OK with attaching the coolant sensor.
or
call the supplier and tell them you have a defective part... can that part be replaced on the radiator or swapped from the old radiator?
Hand tightened nut will hold more than 15PSI, but in your case, the thread is defective so get a replacement new unit.
All tips right on and much appreciated. the ... rig might work and if so would certainly be easiest and quickest. Bot the rad on Fleabay for good price, but man oh man am I getting tiired of getting screwed up stuff from those vendors.
As bad as parts I'm getting from well established, well known BMW parts suppliers.
It is very rare for me to get screwed on ebay... Only once I got screwed badly but all the other transactions went good... over 500+ purchases.
Buying Baer is the same regardless you bought it from eBay or BMA... there are some bound to be defective. Is it possible that you are missing a gasket or something?
Same thing just happened to me. Then I noticed a new nut taped to the inside of the packaging, with a new o-ring.
Pisser of it was, that once it was all installed, the damn thing leaked from where the expansion tank meets the black plastic at the bottom. New stinkin' radiator! Do it again!
Pat Washburn
Wausau, WI
1995 525iT
If you decide to run what you've got try using teflon paste rather than T tape. It will help to hold the nut.
Thanks, all. Plumbers teflon tape fixed it.
