Results 1 to 2 of 2
Thread: e34 Vital's ... Still going strong!
    Mar 2007
    Liverpool UK
    Default e34 Vital's ... Still going strong!
    I was always impressed by the beauty of these cars, but only since owning one have I been blown away with the build quality and how well they age. Mine is 19 yrs old now, and from the looks of it still going strong. There's not many cars out there now this age, never mind in 'working' condition! Here's the 'vitals' that've been checked since I bought it!
    Compression Test:
    HIGHEST POINT REACHED (psi)
    #1 - 180
    #2 - 180
    #3 - 190
    #4 - 190
    #5 - 186
    #6 - 186
    SETTLED VALUE AFTER SEVEN CRANKS (psi)
    #1 - 173
    #2 - 173
    #3 - 181
    #4 - 186
    #5 - 180
    #6 - 182
    Engine Vacuum
    Vacuum = 19 inches/HG (apparently between 16 and 22 is expected for a good motor - Cheers Whisky! )
    Fuel system Pressure
    FP = 41psi with the engine off (spec'd @ 43psi)
    = 36psi with engine running, which is
    Residual pressure seems pretty good too.
    I'd be really interested to see what figures are like out there for the rest of you... Anyone as boring as me who feels like posting them it would be most appreciated!
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Default Compression
    I have a 192 525i with 176k miles, manual. I had it in at my son's auto shop when it was missing on one cylinder a few months ago. (Problem was a bad coil.) They tested the compression (I am not sure peak v. settled) and told me it was 185 +or- 2 lbs all across the board. This car will become my son's car as I just got a used e39 530i.
    I fully expect the next 20 to 30 k miles to be trouble free as most of the problem areas have been dealt with within the last 2 to 3 years. New clutch at 165k (original), new thrust arm bushings at the same time along with tranny mounts, oil pan gasket, valve cover gasket; in the last few months a new radiator, thermostat, water pump last year, all new hoses, new brake rotors and pads front and rear; new fuel pump two years ago.
    Fingers crossed, but the car drives very well, tight and solid with no squeaks or rattles, and still averages 19 mpg.
  1. Strong gas smell
    By rockin1978TA in forum 5 Series BMW
    Last Post: 01-11-2009, 08:49 PM
  2. How strong is the e34 auto tranny?
    By RIPDOTCOM in forum 5 Series BMW
    Last Post: 08-13-2006, 08:38 PM
  3. strong Fuel Smell in car
    By jmr898 in forum 5 Series BMW
    Last Post: 10-14-2005, 06:16 PM
  4. strong Fuel Smell in car
    Last Post: 10-13-2005, 12:36 PM
  5. Strong Fuel Odor
    By John D in forum 5 Series BMW
    Last Post: 11-09-2004, 05:58 PM
