Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: E38 M Par tire size on E34
    Nov 2006
    Maryland
    Default E38 M Par tire size on E34
    What do you guys think of this tire size set up on stock suspension?
    FRONT: 245/40/18
    REAR: 275/35/18
    Nov 2005
    Are you sure the 275's will fit ? Do you expect to run spacers ? M-Pars are pretty hot. You'll be getting one sexy ride.
    Nov 2006
    Maryland
    no spacers, i'm trying to see what will be best for the rear 9.5" wide wheels.
    Nov 2005
    The bmwe34.net website suggests 265 35 18 as the largest 18 inch wheel for the e34, and 275 30 19 for 19 inch. The offset of the e38 is 23mm, where the e34 is 20mm except for the M5. This means the wheels of the e38 would be about 1/8" farther in. And since the wheel is 9.5 inch wide, this brings it closer to the struts.
    I have not test fitted any, so I'm no real help except for the theory. It would be ideal to have someone who has 'em to chime in, or for you to test fit the rim without rubber at least.
    You might try this forum:
    http://forums.bimmerforums.com/forum/index.php
    There's a specific thread for wheels, and another for the e34 that is much more active.
    Renton,WA
    I have 265/35 on my rear m parallels. I had to roll the rear fenders to avoid rubbing with weight in the car.
    __________________
    Nov 2006
    Maryland
    Can someone tell me what would be better for the 8"/9.5" staggared set up.
    245/40/18 all around
    or
    235/40/18(F) & 255/35/18(R)
    Thanks, I cant make a decision, it seems though that the 245/40/18s are more common tires.
    Nov 2004
    Split, Croatia
    Quote Originally Posted by ///Sniper535 View Post
    or
    Neither.
    I have staggered E39 M-Pars (8"/9") and use 235/40-18 front and 265/35-18 rear. I suggest you use the same, since I don't experience any rubbing and 255/35 has smaller diameter than stock.
    Here's how it looks like on my car:
    Nov 2006
    Maryland
    Isnt the offset different vs E38 and E39 M Parallels?
    Nov 2004
    Split, Croatia
    E39:
    - front: 235/40-18 ET20
    - rear: 265/35-18 ET24
    E38:
    - front: 235/50-18 ET13
    - rear: 255/45-18 ET25
    As you can see, in the front there is 7 mm difference, and in the rear only 1 mm. I'm not sure, but you might need spacers in the front. If there's rubbing in the rear, you can always roll the inside of your fenders.
    Sep 2007
    Seattle, WA
    Factory tire size on E34 M-Pars (18x8et20 & 18x9et22) was 245/40/18 all around. Unless 245 is too narrow for the 9.5" width E38 rim I'd run 245/40/18 on all corners.
  1. tire size
    By h2oyo in forum 5 Series BMW
    Last Post: 04-21-2009, 05:36 PM
  2. tire size
    By charlie in forum 7 Series BMW
    Last Post: 10-20-2007, 06:20 PM
  3. Tire size for e34/540/6 with 18s
    By 540ii in forum 5 Series BMW
    Last Post: 08-12-2006, 08:10 PM
  4. Rim and Tire size
    By Borgiulo in forum 3 Series BMW
    Last Post: 01-10-2006, 12:43 PM
  5. what tire size for 16s?
    Last Post: 03-14-2005, 12:12 AM
