Hi Tim...
I think the easiest way to dial in the air/fuel ratio is an adjustable MAF. Not sure what options exist for the M3 - if any exist at all. I was impressed how easy it was for the dyno guys to dail in Martin's car using the controller that came with the pro-flow maf (www.pro-flow.com).
This isn't to say there isn't some sort of problem too. Pinging sure suggests somethings wrong, doesn't it? Does the M3 motor have adjustable cams/Vanos? Might check to make sure that mechanism is working correctly. Trust you've gone thru all the other usual suspects:
- fuel pressure and flow
- fuel quality
- tune up / quality ignition
- vacuum leaks
- blah blah blah...
Curious how it turns out...
Jeff
Originally Posted by
TC535i
Another interesting tidbit, there was a sharp dip in the graph around 6,000 rpm, probably the engine retarding the timing due to detonation. What bothers me is that the A/F ration was 13:1 at that point (plenty of gas), hood open, fan blowing on the intake (CAI/airbox), good Chevron 91 octane, and she's running Denso plugs 1 temp range colder than stock... why the hell would it be detonation? We've heard pinging on occasion too, can't figure out why it would do that. Any guesses?
Bellevue WA
86 Porsche 951 - Track Toy
