Water pump? Tensioner? Remove the belts and start the engine. If the noise goes away, its some component attached to the belt. If it stays, its engine-related.
Hey guys
I started the car fine. moved it outside for a hand wash. opened the hood and the valve cover. watched the valve clearance. no more clearance at the 6th exhaust valve. it is stuck and hard. seat valve need to redone. want to drive to the shop who repairs engines but when i start the car again I have this sound which i never had before even though my valve was already without clearance. this car won't move anymore and I will bring the cylinder head without showing them the head when still in the car.
but still curious to understand what makes this whining noise. thx for any input. it sounds like a belt but at the same time it comes from the head.
http://www.youtube.com/watch?v=fpuCKYhUn0M
Sounds like a bearing 'picking up'-you can get that sort of squealing noise if the outer race of the bearing is turning in the housing instead of staying put.
That sounds vile. Did you check all the rocker clearances then? Is the oil spraybar working? Sounds like it's going to granade if you run it much longer.
Regards,
Shaun M
Do you have a really long screw driver or rod?
Find one or get a mechanic's stethoscope (even cheapo ones are good to have)
Poke around the motor to locate the noise, just rest the tip of the screw driver or rod against the suspect part and press it to your ear. It will become very apparent what is failing.
Eyuuuk!
Pull the valve cover off, from the sound of it something will be pretty obviously fubarred. The sound does seem to be the mid to rear area of the head. If you had a bent valve you would have excess clearance not zero clearance. Sounds like somethings starving for oil.
@blitz. i did use a stetoscope and man the noise was so loud and strident it didn't make any difference.
i did pull the cover off afterwards and everything seemed 'normal'
starving for oil yea. this scares me everytime I open the cover off that something falls in the oil passage. I'm 99% positive nothing fell. But for the sake of the exercise. what would happen if a nut/a bee/ a twig, fall into one of the oil passage. what happen next? will it be pumped by the oil pump to the oil filter and then the the cylinder head passages?
