Oil passage? are you referring to where the oil drains back into the pan? Not much would happen there however if something fell into the pressurized passage say at the cam journal would cause oil starvation. If something fell into the oil filter housing on the wrong side it would be pumped right into oil passages blocking the pressure. Oil from the pan goes to the pump, then to the filter housing, through the filter and then direct to where it needs to go to keep everything from sounding like your video.
Originally Posted by
Mordan
this scares me everytime I open the cover off that something falls in the oil passage. I'm 99% positive nothing fell. But for the sake of the exercise. what would happen if a nut/a bee/ a twig, fall into one of the oil passage. what happen next? will it be pumped by the oil pump to the oil filter and then the the cylinder head passages?
